Norman_Zhang's avatar
Norman_Zhang
May 31, 2021
X-Forwarded-For Log iRule
Currently I have "Insert X-Forwarded-For" field enabled on a http-custom profile. I would like to capture the field in the F5 log.
* To enable this, I need to disable http-custom profile and use iRule to insert and log X-Forwarded-For?
* For the iRule, would this be sufficient?
HTTP::header insert X-Forwarded-For [IP::remote_addr]
log local0. "X-Forward-IP: [IP::remote_addr]"
  • Hi Norman,
    you don't have to disable the custom HTTP Profile. You can use this iRule to log the XFF header which was set by the HTTP profile.
        if { [HTTP::header values "X-Forwarded-For"] ne "" } {
            log local0. "X-Forwarded-For: [HTTP::header X-Forwarded-For]"
    The iRule will read the XFF value which was inserted by the HTTP profile.
    KR
    Daniel
