25-Nov-2019 15:40
Folks,
I have been trying to access some files from the box since we upgraded the code on F5 (14.1.0.6), can someone help me understand if it has to do with some settings on F5? if so, how can I fix this? Getting the below error -
Received too large (1936094320 B) SFTP packet. Max supported packet size is 1024000 B. The error is typically caused by message printed from startup script (like .profile). This message may start with "sftp". Cannot initialize SFTP protocol. Is the host running a SFTP server?
Thank you!
Solved! Go to Solution.
03-Dec-2019 20:27
This is the article i was referring to
K16621651: Error Message: Received too large (1936094320 B) SFTP packet
https://support.f5.com/csp/article/K16621651
Refer to the recommended actions.
25-Nov-2019 23:55
Can you try to login LB device via root user and transfer the file because we face some challenges V13.x.
Below link may help you.
http://www.vmwarearena.com/winscp-connection-to-vcsa-failed-received-large-sftp-packe/
26-Nov-2019 07:31
Thank you Samir, unfortunately, this option does not work for me.
26-Nov-2019 04:19
If you have remote authentication option on F5 you must create local user (named with same as remote user) to connect via sftp.
Or follow this article;
https://support.f5.com/csp/article/K22885182
26-Nov-2019 07:30
I followed the later article you mentioned for a time being now. Thank you so much. Need to explore the first option though. Do we need to have root privileges to create a local user account? Also, where can we check the rights given to us on the box?
26-Nov-2019 22:12
If you dont want to solve this problem in winscp side, you should create local user on F5.
For example; you have AD user named Anju. You will create local user named Anju and give it "advanced shell" right. After that you will login with AD user&pass with "advanced shell" right. ( Only users which have Administrator or User Manager role can create local users)
To see what is your rights, simply when you login CLI you can not pass to shell with "run util bash" command, Only you will have tmsh access.
Don't forget that it is workaround solution. On newer software versions users which have not Advanced shell rights can not make sftp connection. And it is by design.
27-Nov-2019 17:45
I remember there is an article for this. Meanwhile, you only encountered this recently, then it's due to the fix at
https://support.f5.com/csp/article/K38941195
You can grant your user Administrator role with Advanced shell access. System-> Users-> username
OR
For Administrator role w/o Advanced shell access, on wincp, use the SCP protocol + click Advanced
Environment, select SCP/Shell, for Shell, type bash
Ok then connect
03-Dec-2019 20:27
23-Dec-2019 08:58
Thank you!
