sungwon's avatar
sungwon
Oct 15, 2021
Solved
Where is F5 BIG-IP LTM node Field Description
Hi All, I have one question for yours about iControl REST API ltm.
Device traffic information was obtained through "tmsh show ltm node" cli.
so what is mean bits, packet, ? it just total counter ?
Status
 Availability  : unknown
 State     : enabled
 Reason     : Node address does not have service checking enabled
 Monitor    : none
 Monitor Status : unchecked
 Session Status : enabled
Traffic        ServerSide General
 Bits In            0    -
 Bits Out           0    -
 Packets In          0    -
 Packets Out          0    -
 Current Connections      0    -
 Maximum Connections      0    -
 Total Connections       0    -
 Total Requests        -    0
 Current Sessions       -    0
  • Bits In and Bits Out are counters that represent the total number of bits sent between the BIG-IP system and the back end node since the BIG-IP system started up or since the last time statistics for the node were reset. Packets In and Packets Out operate similarly except they represent the number of packets sent between the System and the specified node. All statistics counters can be reset at any time by issuing the command:
    tmsh reset-stats /ltm <node>
    Does that answer your question or are you looking for additional information on all the counters?
    • sungwon's avatar
      sungwon
      First of all, thank you for your reply.
      but i want more information about counter, where is document site ?
