candc's avatar
candc
Icon for Cirrus rankCirrus
Mar 15, 2019
What actually happens when virtual is called from an iRule?
Consider two virtual servers, VS1 and VS2, with iRules IR1 bound to VS1 and IR2 bound to VS2.
If IR1 has...
    log local0.info "start IR1"
    virtual VS2;
    log local0.info "end IR1"
...and IR2 has...
when CLIENT_ACCEPTED {
    log local0.info "in IR2:CLIENT_ACCEPTED"
    log local0.info "in IR2:HTTP_REQUEST"
...what actually happens when I browse to VS1?
  1. Does the iRule processing hit the virtual call in IR1 and call into IR2?
    • if so, does it call into the same event in IR2 that it was at in IR1 (i.e. into HTTP_REQUEST, or does it start again, i.e. at CLIENT_ACCEPTED)
    • would processing return to the code in IR1 after the virtual call?
  2. Or does it proxy a separate, intermediate web request to VS2?
    • if so, what state is retained from the original request to VS1
    • does anything process the code after the virtual call?
Or does something else happen, entirely?
  • Hi candcgroup,
    the virtual command basically used the specified VS instance as a pool member. The connection flow would be CLIENT <-> FrontEndVS <-> BackEndVS and vice versa.
    Use the Virtual Server and iRule setup below to see the involved OSI layers and iRule events in action to serve a single GET request. The log file at the buttom shows you the order of the individual iRule events on both Virtual Servers...
    [root@f501:Active:Standalone] config  tmsh
    root@(f501)(cfg-sync Standalone)(Active)(/Common)(tmos) load sys config merge from-terminal
    Enter configuration. Press CTRL-D to submit or CTRL-C to cancel.
    ltm virtual VS_FrontEnd {
        destination 172.22.17.223%1:https
        ip-protocol tcp
        mask 255.255.255.255
        profiles {
            clientssl {
                context clientside
            serverssl {
                        context serverside
            http { }
            tcp { }
        rules {
            iRule_FrontEnd
        source 0.0.0.0%1/0
        translate-address enabled
        translate-port enabled
    ltm virtual VS_BackendEnd {
        destination 172.22.17.224%1:https
        ip-protocol tcp
        profiles {
            clientssl {
                context clientside
            http { }
            tcp { }
        rules {
            iRule_BackEnd
        source 0.0.0.0%1/0
    ltm rule iRule_FrontEnd {
        log local0.debug "Client [IP::client_addr]:[TCP::client_port] connected to VS_FrontEnd on [IP::local_addr]:[TCP::local_port]."
    when CLIENTSSL_HANDSHAKE {
        log local0.debug "Client [IP::client_addr]:[TCP::client_port] esatblished TLS Channel with VS_FrontEnd on [IP::local_addr]:[TCP::local_port]."
        log local0.debug "Client [IP::client_addr]:[TCP::client_port] requested URI = [HTTP::uri]."
    when SERVER_CONNECTED {
        log local0.debug "VS_FrontEnd using [IP::local_addr]:[TCP::local_port] is connecting to VS_BackEnd on [IP::remote_addr]:[TCP::remote_port]."
    when SERVERSSL_HANDSHAKE {
        log local0.debug "VS_FrontEnd using [IP::local_addr]:[TCP::local_port] established TLS Channel with VS_BackEnd on [IP::remote_addr]:[TCP::remote_port]."
    when HTTP_REQUEST_SEND {
        log local0.debug "VS_FrontEnd using [IP::local_addr]:[TCP::local_port] is forwarding the HTTP request to VS_BackEnd on [IP::remote_addr]:[TCP::remote_port]."
    when HTTP_RESPONSE {
        log local0.debug "VS_FrontEnd using [IP::local_addr]:[TCP::local_port] got a HTTP response from VS_BackEnd on [IP::remote_addr]:[TCP::remote_port]"
    when HTTP_RESPONSE_RELEASE {
        log local0.debug "VS_FrontEnd using [IP::local_addr]:[TCP::local_port] is forwarding the HTTP response to Client on [IP::client_addr]:[TCP::client_port]"
    ltm rule iRule_BackEnd {
        log local0.debug "VS_FrontEnd using [IP::client_addr]:[TCP::client_port] connected to VS_BackEnd on [IP::local_addr]:[TCP::local_port]."
        log local0.debug "VS_FrontEnd using [IP::client_addr]:[TCP::client_port] esatblished TLS Channel with VS_BackEnd on [IP::local_addr]:[TCP::local_port]."
        log local0.debug "VS_FrontEnd using [IP::client_addr]:[TCP::client_port] requested URI = [HTTP::uri]."
            log local0.debug "Sending HTTP response to VS_FrontEnd on [IP::client_addr]:[TCP::client_port]."
            HTTP::respond 200 content "OK"
    }Loading configuration...
    root@(f501)(cfg-sync Standalone)(Active)(/Common)(tmos) quit
    [root@f501:Active:Standalone] config  tail -f /var/log/ltm
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : Client 172.21.92.19%1:52406 connected to VS_FrontEnd on 172.22.17.223%1:443.
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : Client 172.21.92.19%1:52406 esatblished TLS Channel with VS_FrontEnd on 172.22.17.223%1:443.
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : Client 172.21.92.19%1:52406 requested URI = /.
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : VS_FrontEnd using 172.21.92.19%1:52406 is connecting to VS_BackEnd on 172.22.17.224%1:443.
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_BackEnd : VS_FrontEnd using 172.21.92.19%1:52406 connected to VS_BackEnd on 172.22.17.224%1:443.
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : VS_FrontEnd using 172.21.92.19%1:52406 established TLS Channel with VS_BackEnd on 172.22.17.224%1:443.
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : VS_FrontEnd using 172.21.92.19%1:52406 is forwarding the HTTP request to VS_BackEnd on 172.22.17.224%1:443.
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_BackEnd : VS_FrontEnd using 172.21.92.19%1:52406 esatblished TLS Channel with VS_BackEnd on 172.22.17.224%1:443.
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_BackEnd : VS_FrontEnd using 172.21.92.19%1:52406 requested URI = /.
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_BackEnd : Sending HTTP response to VS_FrontEnd on 172.21.92.19%1:52406.
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : VS_FrontEnd using 172.21.92.19%1:52406 got a HTTP response from VS_BackEnd on 172.22.17.224%1:443
    Mar 18 16:40:26 f501 debug tmm1[12155]: Rule /Common/iRule_FrontEnd : VS_FrontEnd using 172.22.17.223%1:443 is forwarding the HTTP response to Client on 172.21.92.19%1:52406
    ^C
    Note: If you look carefully to the resulting log file of this demo setup, you will notice that the FrontEnd Virtual Server will even negotiate a TLS channel with the BackEnd Virtual Server. So better make sure the FrontEnd Virtual Server does not utilize a ServerSSLProfile and the BackEnd Virtual Server does not utilize a ClientSSLProfile.
    Cheers, Kai
