tihi's avatar
tihi
Sep 20, 2019
Weird rpm-tmp files are taking up too much space in /shared
Hi everyone,
We have a Viprion device with 2 guests on it. On one of them we keep getting this error:
011d0004:3: Disk partition /shared (slot 1) has only 15% free
Upon further investigating the /shared folder, we realized that the /shared/tmp folder is filled with almost 23 gigs of random tmp files, such as:
rpm-tmp.bw2ttL
rpm-tmp.BWk9SZ
rpm-tmp.BWLzYD
rpm-tmp.BXUvXL
rpm-tmp.BYAz3r
rpm-tmp.bYeToN
rpm-tmp.BYuy6l
rpm-tmp.bYyVMg
They are usually around 9-12 MB in size and there is a lot of them.
My questions are since I couldn't find any info on them:
What are these?
Can they be deleted?
Thanks in advance.
  • Hello Tihi.
    Those files are created as part of a Build RPM Package process.
    REF - https://linux.die.net/man/8/rpmbuild
    I share with you some other references:
    REF - https://www.redhat.com/archives/rpm-list/2003-September/msg00099.html
    REF - https://www.redhat.com/archives/rpm-list/2003-September/msg00100.html
    Example of execution
    $ rpmbuild -bb doc.spec
    Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.X07xhN
    + umask 022
    + cd /home/neo/rpmbuild/BUILD
    + exit 0
    Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.ANzKAA
    + umask 022
    + mkdir -p /home/neo/rpmbuild/BUILDROOT/netkiller-1.0.1-1.x86_64
    + mkdir -p /home/neo/rpmbuild/BUILDROOT/netkiller-1.0.1-1.x86_64/usr/share/doc/
    + exit 0
    Usually, those files are removed at the end of the packet construction. Why are they not being removed? actually I don't know. You should better open a support case.
    KR,
    Dario.
    • tihi's avatar
      tihi
      Thank you for your reply. I'll look into the references and open a support case.
      Thanks again.
      Br,
      Tihi
  • Brumik's avatar
    Brumik
    Hello,
    I am getting the same issue - rpm tmp files are created in /var/tmp each morning.
    Does anyone know what process is creating these and how to stop it?
    BR
    Chris
