Aaron_Warner_11's avatar
Aaron_Warner_11
Feb 26, 2019
Solved
vCloud HTTPS monitor broke after upgrade of backend vCloud director
I have a very simple monitor for vCloud director.
the Send String was
GET /cloud/server_status \r\n
and the receive String was
Service is up.
This was happy and fine, then we upgraded from vCloud 9.0 to 9.5 and suddenly the monitor started failing. We still have both versions running so I can do comparisons. Initially the monitor error stated that HTTP 0.9 wasn't supported on the backend server, so I modified the Send String to send that included HTTP 1.1 thinking this would sort me out.
So now my Send String looks like
GET /cloud/server_status HTTP/1.1\r\n\r\n
and Receive String looks like
Service is up. HTTP/1.1
The F5 monitor is saying its getting back a 400 bad request error but I'm really unsure why.
Doing a verbose curl I get the following response.
Legacy 9.0
< HTTP/1.1 200 OK
< Date: Mon, 25 Feb 2019 19:37:47 GMT
< X-VMWARE-VCLOUD-REQUEST-ID: 46386830-291d-45ab-89ce-c89188dc2746
< Cache-Control: no-cache, no-store, max-age=0, must-revalidate
< Pragma: no-cache
< Expires: 0
< Strict-Transport-Security: max-age=31536000 ; includeSubDomains
< X-XSS-Protection: 1; mode=block
< X-Frame-Options: SAMEORIGIN
< X-Content-Type-Options: nosniff
< Transfer-Encoding: chunked
Service is up.* Connection 0 to host host.name left intact
Updated 9.5 Response
HTTP/1.1 200 OK
< Date: Mon, 25 Feb 2019 19:37:02 GMT
< X-VMWARE-VCLOUD-REQUEST-ID: b1e654da-ef3d-4560-aad3-6690509ce219
< Content-Security-Policy: default-src *  data: blob: 'unsafe-inline' 'unsafe-eval'; script-src * 'unsafe-inline' 'unsafe-eval'; connect-src * 'unsafe-inline'; img-src * data: blob: 'unsafe-inline'; frame-src *; style-src * data: blob: 'unsafe-inline'; font-src * data: blob: 'unsafe-inline';
< Vary: Accept-Encoding, User-Agent
So I'm really confused as to what it is about the new response thats breaking the monitor. Any suggestions are appreciated.
  • Try adding a Host: header to your send string. I believe HTTP/1.1 requires it even if it is empty.
    Something like
    GET /cloud/server_status HTTP/1.1\r\nHost:\r\n\r\n
    Hope that helps! If it does please up-vote and select this answer, it'd be greatly appreciated!
    -Dylan
    Something like
    -Dylan
    • Aaron_Warner_11's avatar
      Aaron_Warner_11
      Thanks Dylan you were exactly right, I didn't realise Host: was a required parameter for http 1.1 (rtfm?). I added it with a blank address and it was fine. Thanks heaps for your help.
