Technical Forum
Using service port lists
pbol
Hi
I am a little stuck and was hoping someone can point me in the correct direction.
I have a single node (10.1.1.1) which has 2 applications running on it (application 1 on port 8080 and application 2 on port 9090)
I have created the Node entry in LTM using the GUI (10.1.1.1)
I have created a Pool called "Default_Pool"
I have created a VS called "Default_VS" with the IP 10.0.1.1
I have created a Port List called "Default_Port_List" and associated it with the VS "Default_VS". My port list contains both port 8080 and 9090
I am stuck now as to how to do I add the same node with 2 different ports as a member of the same pool "Default_Pool".
How do I ensure that traffic from the Default_VS (10.0.1.1) on port 8080 is only hitting the node 10.1.1.1 on port 8080 ?
1 REPLY 1
crodriguez
Legacy Employee
Legacy Employee
A simple solution is to simply create two virtual servers, one at 10.0.1.1 port 8080 that load balances to a pool with one member at 10.1.1.1:8080, and another at 10.0.1.1 port 9090 that load balances to a different pool with one member at 10.1.1.1:9090. You can have two virtual servers listening on the same IP address but different ports and two pools with the same underlying node. This solution does not require port lists or any sort of logic via an iRule or Local Traffic Policy to examine the port on the client-side request and select the appropriate pool member.
