09-Oct-2018 06:43
Hello all,
I want to use OpenID Connect to authenticate my users before gaining access to one of my application. I want to use my bigip as OpenID Provider (ie: the entity that authenticate the users) . My issue is the following: The OpendID provider (my bigip) never provides me with a ID Token. All I have is an “Access Token” and a “Refresh Token” but no “ID Token”.
Below is a description of my lab:
resource owner: ip address 10.10.255.1
bigip OpenID Provider: virtual server ip 10.10.255.221 (see below for the access policy)
*The agents are left with their default values.
I do the following for testing :
I request the authorization code from the authorization server (ie my virtual server) . For this I use openID Connect debugger to construct the request for me. Here is the request that I send :
? client_id=e1111098ccff5f81859f9fc83eaa000c29267803efc0bb5b & redirect_uri=https://oidcdebugger.com/debug & scope=openid myscope & response_type=code & response_mode=form_post & state=toto & nonce=7r8saarltr
After sending this request I enter my credentials (in the logon agent), I click on authorize then the virtual server correctly redirects me to:
https://oidcdebugger.com/debug code=cae85f6fd33c6b27f56f536b6fd9af2ca0fc78e69ac3d13799533c143b38b4ac&state=toto”
I now have a correct authorization code that I can exchange for an “access token” AND a “ID Token” .
I then send a POST to get the access and ID Tokens using the following HTML code :
*note the presence of the “openid” in the scope parameter.
However, this is what I get from the authorization server (see in the comment) :
-> I have No “ID TOKEN” ☹
Could you please help me configure my access policy so that it supports OpenID Connect and sends me an “ID Token” ??
09-Oct-2018 06:44
Here is the Tokens I get :
{ "access_token":"ewogICJhbGciOiJSUzI1NiIsCiAgImtpZCI6ImFkbWluIgp9.ewogICJ0b2tlbl90eXBlIjoiQmVhcmVyIiwKICAic2NvcGUiOiJteXNjb3BlIiwKICAic2NvcGVfZGF0YSI6WwogICAgewogICAgICAgICJpZCI6Im15c2NvcGUiLAogICAgICAgICJ2YWx1ZSI6ImthcmltIgogICAgfQogIF0sCiAgImlzcyI6Imh0dHBzOi8vb2F1dGgua2FiZS5sYWIiLAogICJteWNsYWltIjoia2FyaW0iLAogICJzdWIiOiIvQ29tbW9uL2thYmVfb2F1dGhfYXV0aG9yaXphdGlvbi5rYXJpbSIsCiAgImp0aSI6ImY5MTQyMGQxMDYzMmNiNmY5MTM2OGU1ODI4ZDdhNWI1YWIxZDRhYWI1ZDVmNTVlN2ZlZjY1NjBiOWFkNjQxMDIiLAogICJpYXQiOjE1MzkwODk3ODMsCiAgImV4cCI6MTUzOTA5MDA4MywKICAibmJmIjoxNTM5MDg5NDgzCn0.aTeXibnRqICbXDT84x7US6eMxx7Sdb5fDUHbpBSjvHVSKPHKRDcOoG76PTm9cOedJAH4WfgCNT1AmKE1uI0C-tUvdSPaBIpVOfLUGec9MyG2Fj1v-eeV3HoEM1RypdYvLAcGLR-AoZgbn2mca40CJPHAyw8yonpdxgNhVR3l4pzmi3xhv9hlnizNjXIG2J2qNU_2lGJfA8L2LoNKF7oEWk77_erutWKLwcuwSIdO2i5Rrr2vNahV-nxI4BG4jQXcgVJS8K4dGOe4gZwK-aBbRoliEX4DG2gLJ4t07BlvboHeHLpy7KagsRu_0yaChxqZ65l1e-zGvBjAhbu3jwAvqw", "expires_in":"300", "token_type":"Bearer", "scope":"myscope", "refresh_token":"CEJ7xkwqXJKPN8PQnnmUlRlSaI5Y6XsvIPzPq3zURuZCLn4AIak7WfasNA-ccM3Ejc1mPv6gxSAO5CgkolyQejGlw9tvIBP16y9kutn66nV7ecl7DMytO3UBQUt55RvAwfhqkyRKkjy4u5DudNOBS4wH20FfIMhM4XY3nto3yINYAewYVzpv4wIhZnZKPXRIq5qEUPhjaU-szAoLfX9aBIRmrhmGoWfgG2T3uQW7fjwfTRFzb_LkzXCi4dsAzq-WjDoBuQ4fSv6cqoRP66P9XygHODPcl0ldaOssH_oVPiXQoppKZ_I_2Bce4qcHmkobzQzZWlVvxFbnvyRCCf9-xN9PpO2d7OYzNO-2wODQEmLSHKSpnRl7Oa8A1nlDA4gZ_ks8OAz1Q0vyZgM9YcCErF1NBUN-wCTMfXBvRcNza-8z9ITDbmKlntIE9XVl9NMTHcvY1RlhLSwwsfYa67ZBSoMX67VP1DCfuD45HoBx6A3Uko4L0PxLpUkD1OzjzINTmoAy6DBlGNXnrFZXa0Aic8OHa7VIn1R0zGTfLmBybHnbZI9rN-nyhjr5vqY-HjxB-K_8X9bpmI39oWS3-eriUK1H03_M_t0VO6je3SEXK1GbgjyW2owuhZR4dBgk_eK1M9iSSiHt8Gau1bfl-9t3_prnVlrKips3aIAWIyz2q3yJLytNlejWZXTmycafdqFHerO14Dq4BG1mTcQBjeT7UBP-V3g" }
09-Oct-2018 06:44
Below is my oauth configuration :
apm profile oauth /Common/kabe_ouath {
app-service none
audience none
client-apps {
/Common/kabe_postman { }
issuer https://oauth.kabe.lab
jwt-refresh-token-enc-key $M$Dz$pa6iJ2laNDA7DK2Lk9Lhl0yvxZWSXuUMaMOpe681aKsJaBh+u9fViazYSWYRhITn
jwt-token enabled
opaque-token disabled
primary-key /Common/kabe_jwt_key
apm oauth oauth-client-app /Common/kabe_postman {
app-name openid_debuger
client-id e1111098ccff5f81859f9fc83eaa000c29267803efc0bb5b
client-secret 7c40cd50e3a99c99caefb35d6cfa000c29267803efc0bb5b
customization-group /Common/kabe_postman_oauth_authz_client_app_customization
grant-code enabled
redirect-uris { https://oidcdebugger.com/debug }
scopes {
/Common/kabe_scope { }
apm oauth oauth-scope /Common/kabe_scope {
customization-group /Common/kabe_scope_oauth_authz_scope_customization
scope-name myscope
scope-value "%{session.logon.last.username}"
apm oauth jwk-config /Common/kabe_jwt_key {
alg-type RS256
cert /Common/default.crt
cert-chain /Common/default.crt
cert-key /Common/default.key
cert-thumbprint-sha1 nbfOLqFiwWesgPxQXUrvoCyyZBk
cert-thumbprint-sha256 ha7lBh7DSPvDzMtboP2NJ9zcI4B8wo9oJhy8sHeng3w
key-id admin
modulus p6Vhksrx3oxndL1ZOBS4CoCVumA_xw4n31yftdAyeiL3NRPO- Pa4sAopJ3S1f5joQeYLQWcxRvhp94SgeklF_BDk8gGLAjloCs1ENmCt84ktULPiItOCrHx_zsjm-dO7Dmj7RwTQahqzipLq1BN0Bqaf35jNcVOTdR1CbW2qRDGmpl407Bk9VKaHIHv17ivZW4ACWoWgyx884FTzmIr5juAEOPuJvcq_pJNctrmK6VUrumNX-uTtsHg36FGVZSVcfcZnhKOUzhwT9fD9uD1xdlmQJLbHipZM8GpKsfGm-NdnmuLiK47L9PYiEleXVOF6McT3zmj3DRW1NztnH80isw
passphrase $M$8p$wqUeSn31SPsxWhnp4opxnA==
public-exponent AQAB
31-Oct-2018 10:55
Support for this only seems to start in version 14.0.0.
From the release notes:
Authorization server support for OpenID Connect
APM includes OpenID Connect support in the APM Authorization Server Framework for ID token and UserInfo generation.
13-Nov-2018 00:35
We have upgraded to version 14.0.0.1 build 002 and have OAuth 2 working as an authorization server. We would like to enable OpenID in order to access ID token so we can request UserInfo attributes. Has anyone successfully enable OpenID on the F5(Provider)? Anyone have a working example?
28-Jan-2019 18:14
In my own lab environment I had to disable opaque tokens and enable jwt (14.1).
The following is roughly what it looks like
apm profile oauth oauth-oidc-profile {
app-service none
audience none
client-apps {
oauth-oidc-client { }
id-token-primary-key myrsa
issuer https://issuer.example.com
jwt-refresh-token-enc-key [redacted]
jwt-token enabled
openid-connect enabled
primary-key myrsa
resource-servers {
oauth-api-rs { }
userinfo-primary-key myrsa
Results in
"access_token": "ewog...NifA",
"expires_in": 300,
"token_type": "Bearer",
"scope": "openid",
"refresh_token": "nrY...i62",
"id_token": "ewog...LUCA"
06-Feb-2019 15:11
This helped alot however be aware, in a HA pair if you use the default .crt/.key as per this config you will get sync errors, it's not immediately obvious.
For Certificate File, select a certificate. Important: Do not select the default certificate when the BIG-IP system is on a chassis platform or is included in an HA pair. F5 strongly discourages the use of the default certificate in a JWK in any configuration. For Certificate Key, select one. Important: Do not use the default key when the BIG-IP system is on a chassis platform or is included in an HA pair. F5 strongly discourages the use of the default key in a JWK in any configuration.
11-Mar-2019 04:46
should we create the openid scope?
14-Feb-2022 12:01
I was wondering if anyone figured out why user info is not being provided to servcie provider? I am trying to connect ESRI using open ID but keep getting user profile parameter is not received from providor.
I know I have ESRI configured correctly because if I use google as my IDP for oauth I am able to authenticate.
I tried to create a scope of openID in version 14.1 and said that can't be used.
Oauth profile:
I have Opaque Token turned off
I have support for JWT Token and OpenID connect enabled
It is also strange that teh userinfo endpoint url page won't come up but that may be because you can't access it directly.
Anythoughts would be great. Thank you
