Blue_whale's avatar
Blue_whale
Jan 22, 2020
URL to URI redirect irule required
Hi Team ,
we have 2 different applications hosted on the server , that can be accessed through 2 URI :
/ckpartner
/cklauncher
On f5 we want to redirect all requests on www.example.fr to www.example.fr/ckpartner
www.example.fr/cklauncher do not have to be exposed on the Internet
Can you please help me with irule for this redirect .
  • Hello Chethan.
    you could try with this irule
        if { [HTTP::host] contains "www.example.fr" } {
            HTTP::uri /ckpartner
    KR,
    Dario.
  • @Dario
    Thank you .
    I have to modify this rule with few more if and else statements , Can you please help ?
    1.Redirect all the request comming from specidic source IP : 10.10.10.10 or 10.10.10.0/24 to www.example.fr/ckpartner
    • Dario_Garrido's avatar
      Dario_Garrido
      Icon for MVP rankMVP
      Hello Chethan.
      Below one example of using URI replacement (first statement) and redirect (second statement).
          } elseif { [IP::addr [IP::client_addr] equals 10.10.10.0/24] } {
      		HTTP::redirect "http://www.example.fr/ckpartner/"
      Note that in the redirect command you should use the adequate scheme (http:// or https://)
      Please, don't forget to mark this answer as "the best" if it was helpful.
      KR,
      Dario.
      • Blue_whale's avatar
        Blue_whale
        Thanks Dario ,
        I tested first irule , it did not work for us .
        We want all the request comming to www.example.fr from specific source 10.10.10.1 to get redirected to www.example.fr/ckpartner/ and this should be logged .
        Can you please check if the below Irule we can achieve this ?
        if { ([IP::addr [IP::client_addr] equals 10.10.10.1]) && ([HTTP::host] starts_with "www.example.fr") } {
        log local0.
        set newUri [string map {"/" "ckpartner/"} [HTTP::uri]]
        HTTP::uri $newUri
  • When clients attempt to access your secure_vs, you don’t want them to have to remember to type HTTPS before the web site, but you also don’t want to open port 80 (HTTP) on your web servers as that is just asking for trouble. To avoid this issue, you will be creating an HTTP virtual server that will redirect HTTP to HTTPS and the secure_vs official website
      Blue_whale
      Thanks for your help ,
      My requirement is currently working with below Irule but I would like to add Datagroup to below Irule so that I can filter more external IP's
      Could you please help me modify this irule .
      I tried but I got error "variable reference required preeciding $"
      if {
                       ([IP::client_addr] contains "10.10.10.1%70") && ([string tolower [HTTP::uri]] contains "/cklauncher/")
                      drop
      elseif { [string tolower [HTTP::path]] equals "/" && ( [IP::addr [IP::client_addr] equals 10.10.10.1%70]) } {
      # redirect the request
      log local0. "issuing redirect request to [HTTP::host][HTTP::uri] from [IP::client_addr]"
      HTTP::redirect https://[getfield [HTTP::host] ":" 1]/ckpartner/
