vinod1's avatar
vinod1
Nov 22, 2022
Solved
iRULE - Redirect irule - Help required
Hello ,
I am working on a redirect request using an iRULE
User has requested the following redirect,
https://abc.xyz.com/Projectsite/*   to  redirect to    https://bbb.xyz.com/page/projectdocs-users/
Can we do an irule with Wildcard in the path. ?
Appreciate your help..
  • Hi vinod1 ,
    you can do it without wildcard in uri , it is sufficient to use "starts_with" operator.
    Please check this :
       if { [HTTP::host] equals "abc.xyz.com" && [HTTP::uri] starts_with "/Projectsite/"}{
       HTTP::redirect "https://bbb.xyz.com/page/projectdocs-users/"
    I hope it fits with your requirements
    Regards
  • Hi vinod1 ,
    Please check this :
    Regards
  • Thankyou very much Mohamed, it worked..
    You saved lot of time..
