David_Lopez_379's avatar
David_Lopez_379
Jan 10, 2019
Upgrading from 11.2.1-HF12 > 11.6.3.3
F5 documentation upgrade path requires that I go from 11.2.1-HF12 to 11.5.0 and then upgrade to 11.6.3.3. There are currently 3 volumes HD1.1, HD1.2 and HD1.3. Currently HD1.1 contains the active running of 11.2.1. The other volumes contain older versions. Is there a limit to the number of volumes? remember I need to go to an interim version 11.5.0 before reaching my target version 11.6.3.3. In addition I want to keep 11.2.1-HF12 just in case we need to rollback.
thanks for your advice in advance!
Our platform: BIG-IP 3900 (C106) HA Pair - Current version: 11.2.1 HF12 - target version: 11.6.3.3
source https://support.f5.com/csp/article/K13845
  • You can delete old version volumes.
    Then when you want to upgrade, volume selection allow to set a new volume name instead of selecting an existing!
    For HD1.2, enter only 2
    You can create as many volume as required, in max disk usage limit !
