27-May-2022 18:37
Hi all,
I tried searching this topic and couldn't find any results. I'm trying to clear the statistics for a virtual server and a pool on an LTM, in the GUI, but when I try to clear it, nothing happens.
VS - Statistics - Clear all Statistics
Pool - Statistics - Reset (on all pool members)
I was thinking a GUI bug, and tried in tmsh but no success with commands:
reset-stats ltm virtual vs_name
reset-stats ltm pool pool_name
Anyone have any ideas on how I can clear them, any other methods or ways?
Running BIG-IP 13.1.3.6
Thanks!
29-Aug-2022 15:50
Hello,
You can try reseting the statistics from the GUI: traffic statistics, you navigate to BIG-IP Configuration > Statistics > Module Statistics > Local Traffic, and set the Statistics Type to Pools.
If it still there, try restating http demaon and tomcat and check again.
BR,
MSalah
