27-Oct-2020 02:28
Here is what we are trying to acheive to replace a Microsoft IIS Server.
Many of our client servers are note supporting TLS 1.2, So we have this webserver that acts as a proxy for them.
The IIS Server is presenting a certificate based on a hostname, Then the url requested is parsed ont the IIS server and the original client certificate is presented to the EXTERNAL website and data is exchanged through the IIS Server.
For an exemple :
Client ask for : https://iisredirect.sdswebapp.com/URL=login.decisivapps.com/oauth/token that goes to the IIS server.
IIS Server "comfort" client with it's own certificate.
Request is receveived at https://login.decisivapps.com/oauth/token from the IIS server on behalf of the client.
Then the IIS server exchanges data between them until completion.
We cannot use nodes because all those site are external.
What we've tested so far was an iRule that "works" on redirection only, but not as a proxy.
Our dev team would like to replace this IIS server without having to use nodes,datagroup or so. Only with the /URL=??? method already hardcoded on hundreds of servers.
Is there any way to achieve this ?
Thank you
01-Nov-2020 14:50
You can define nodes that are external to the networks on the LTM.
It's certainly achievable, but not trivial.
I'd suggest approaching F5 Professional Services to get this written.
Otherwise, here is a high-level irule structure
you need server-ssl profiles for all the target severs, with relevant settings and client-auth certificates
They need to be named in a structured way so they can be correctly selected with the host name
get the request URI (HTTP:uri)
split it on "URL=", and keep the second result
Prepend "https://" so you have a target URI for the server-side response
Use URI::host to get the host name
use DNS::resolve to get an IP address from the host name
set the node using the IP address
change the Host header in the request
select the correct server-ssl profile based on the hostname
allow the request to be made
once you have a response, translate any embedded URLs as required
