22-May-2020 07:47
Hello ALL,
Could you please help me to troubleshoot trsut domain creation issue? is there any pre-check list or validation list to identify where the issue is?
Error log:
Troubleshooting trust domain creation issue with error"Unexpected Error: "Timed out while waiting for the device to respond"
[root@SCLLAB-NSO1-LB01:Active:Standalone] config # netstat -pan | grep -E 6699
[root@LAB-LB01:Active:Standalone] config # bigstart status devmgmtd mcpd sod tmm
devmgmtd run (pid 8109) 4 days
mcpd run (pid 8586) 4 days
sod run (pid 8997) 4 days
tmm run (pid 7296) 4 days
root@(LAB-LB01)(cfg-sync Standalone)(Active)(/Common)(tmos)# list sys ntp
sys ntp {
include "server 10.40.33.25 prefer key 900 iburst trustedkey 900"
servers { 10.3.1.25 10.40.33.25 }
' devices <devgroup [device cid.id cid.orig cid.time last_sync
172.31.0.3 :: (mcpd down) (mcpd down)
root@(LAB-LB01)(cfg-sync Standalone)(Active)(/Common)(tmos)# modify /cm trust-domain /Common/Root ca-devices add { 172.31.0.3} name /Common/SCLLAB-NSO1-LB02.CISCO.COM username root password default
Thanks a lot in advance for your help.
Regards,
Thiyagu
