Lani's avatar
Lani
Mar 24, 2021
Solved
Traffic Shaping and Atlassian Jira
Hi All,
I'm having an issue getting Traffic Shaping situated for Jira - here's what I need done:
  1. Sticky Sessions
  2. If the URI is rest - then go to Pool2
  3. Else if that URI is rest/login.jsp - Pool1
  4. All others go to Pool1
The problem I'm having, is it always routes me back to pool2
if { [string tolower [HTTP::uri]] contains "/rest" }{
pool pl-prd-jira.ftr.com2-tcp8080
  • K9815: Using an iRule to select among multiple pools with different members may be incompatible with some cookie persistence configurations
    Link: https://support.f5.com/csp/article/K9815
  • Hi Lani,
    Can you try this irule?
    	if { [string tolower [HTTP::path]] starts_with "/rest" && [string tolower [HTTP::path]] ne "/rest/login.jsp"} {
    	else {
    		pool pl-prd-jira.ftr.com1-tcp8080
    If you need persistence:
    		persist cookie insert "pool-ftr2"
    	else {
    		persist cookie insert "pool-ftr1"
  • Lani's avatar
    Lani
    We got it working - but I'm super interested in the persistence -
    Does this mean, setting persistence within the configuration does not work? unless we add it via iRule?
      • Lani's avatar
        Lani
        Thank you! I really appreciate your help with this!
