14-Feb-2021 10:36
I not clear on the output of the statistics for virtual servers. Mainly on what the F5 LTM considers "Requests" and "Connections". I included a picture of one my my VS statistics. The amount seems high for one VS but i don't know if this is a running total from the time the VS was created or per second or per minute. Need more understanding. Platform is a i7800 with two vCMP.
Jonathan,
15-Feb-2021 06:54
Yes that data is from the time hardware was booted up.
You can clear the stats & monitor for a time frame as you feel required.
15-Feb-2021 17:12
Thank you for the clarification. So, to get a real time statistic i should use the stats from the pool members? I'm only at GUI level but want to learn CLI. Have not found the right command for just getting the statistics. I've been using the "all-properties" for the specific VS, Any advice?
Jonathan,
17-Feb-2021
16:24
- last edited on
04-Jun-2023
21:03
by
JimmyPackets
You can view virtual server and pool statistics from the command line using the show command, rather than list. For example, to show traffic statistics for a virtual server named http_vs:
(tmos)# show /ltm virtual http_vs
To show traffic statistics for all members in the pool named http_pool:
(tmos)# show /ltm pool http_pool members
You can reset statistics for a particular pool, pool member, or virtual server using the reset-stats command. For example, to reset statistics for a virtual server http_vs:
(tmos)# reset-stats /ltm virtual http_vs
Hope this helps!
