rafaelbn_305907's avatar
rafaelbn_305907
May 06, 2018
ssldump first connection doesn't seem to transfer any data
Hello Devs!
When a client connects using IEv11, the first and second TLS connections does not seen to transfer any data. The application is working just fine. I'm just curious about this...
Here is the ssldump of it:
[root@bigip1:Active:Disconnected] config  ssldump -nni 0.0 -A host 192.168.1.43
New TCP connection 1: 192.168.1.224(23180) <-> 192.168.1.43(443)
1 1  0.0023 (0.0023)  C>SV3.1(172)  Handshake
      ClientHello
        Version 3.3
        random[32]=
          db 7d af 76 a5 0b 3c 46 6a 14 43 4f c7 a3 10 80
          07 a7 de 32 0a 0e 5a bf 02 a4 95 b8 bd c7 02 1d
        cipher suites
        TLS_RSA_WITH_AES_256_GCM_SHA384
        TLS_RSA_WITH_AES_128_GCM_SHA256
        TLS_RSA_WITH_AES_256_CBC_SHA256
        TLS_RSA_WITH_AES_128_CBC_SHA256
        TLS_RSA_WITH_3DES_EDE_CBC_SHA
        TLS_EMPTY_RENEGOTIATION_INFO_SCSV
        compression methods
                  NULL
1 2  0.0024 (0.0000)  S>CV3.3(81)  Handshake
      ServerHello
        Version 3.3
        random[32]=
          f6 5a d2 b7 96 30 50 58 84 70 75 7f 38 64 74 8f
          49 b0 87 54 19 02 fb 94 a2 9a 5f dd 1a 5e f0 19
        session_id[32]=
          2a 80 ec 5b ff 45 e0 be 13 49 26 63 66 8d 88 46
          06 76 28 99 38 b2 24 3d 8f 5f 8b 29 36 1d d8 57
        cipherSuite         TLS_RSA_WITH_AES_256_GCM_SHA384
        compressionMethod                   NULL
1 3  0.0024 (0.0000)  S>CV3.3(956)  Handshake
      Certificate
1 4  0.0024 (0.0000)  S>CV3.3(4)  Handshake
      ServerHelloDone
1 5  0.0048 (0.0024)  C>SV3.3(262)  Handshake
      ClientKeyExchange
1 6  0.0048 (0.0000)  C>SV3.3(1)  ChangeCipherSpec
1 7  0.0048 (0.0000)  C>SV3.3(40)  Handshake
1 8  0.0078 (0.0029)  S>CV3.3(1)  ChangeCipherSpec
1 9  0.0078 (0.0000)  S>CV3.3(40)  Handshake
1    0.0158 (0.0079)  C>S  TCP FIN
1    0.0159 (0.0000)  S>C  TCP FIN
New TCP connection 2: 192.168.1.224(23182) <-> 192.168.1.43(443)
2 1  0.0024 (0.0024)  C>SV3.1(172)  Handshake
      ClientHello
        Version 3.3
        random[32]=
          42 2a 47 8e 53 9c e4 da 41 27 7a cb be 18 2b 25
          a9 3e dd 0b f1 da 8c 14 a6 5a 6e 26 5e 8a 1b b8
        cipher suites
        compression methods
                  NULL
2 2  0.0024 (0.0000)  S>CV3.3(81)  Handshake
      ServerHello
        Version 3.3
        random[32]=
          68 2f 0b e4 5b 3d 25 7a 74 69 d1 f4 1b 00 f2 e0
          62 73 d7 23 bb e4 3f 56 be b3 70 7c 48 d2 58 60
        session_id[32]=
          31 dd 8b 6e f4 d1 ef 82 f9 05 a0 d6 3d 78 77 6b
          3c 4b 8f cc 73 47 eb a0 f9 d2 4c fc cd c8 87 3a
2 3  0.0024 (0.0000)  S>CV3.3(956)  Handshake
      Certificate
2 4  0.0024 (0.0000)  S>CV3.3(4)  Handshake
      ServerHelloDone
2 5  0.0052 (0.0027)  C>SV3.3(262)  Handshake
      ClientKeyExchange
2 6  0.0052 (0.0000)  C>SV3.3(1)  ChangeCipherSpec
2 7  0.0052 (0.0000)  C>SV3.3(40)  Handshake
2 8  0.0119 (0.0066)  S>CV3.3(1)  ChangeCipherSpec
2 9  0.0119 (0.0000)  S>CV3.3(40)  Handshake
2    0.0203 (0.0084)  C>S  TCP FIN
2    0.0204 (0.0001)  S>C  TCP FIN
Is this the normal behavior? I can't see any errors. This seems not optimal...
Thanks! Rafael
  • Does this occur with Chrome/Firefox/Edge?
    What is the client-ssl profile configuration?
  • Hello Blakely!
    Yes. All three browsers behave the same. I think this could be the self-signed certificate. Since the browser is expecting the user to accept the security exception, it sends the reset to the server. When the client confirms the exception, the browser starts a new connection. Does that make sense to you?
    If I connect from a linux box through "openssl s_client -connect 192.168.1.43:443", the ssldump is perfect!
    Client ssl is as follows:
    ltm profile client-ssl clientssl_lab.local {
        app-service none
        cert lab.local.crt
        cert-key-chain {
            lab.local_lab.local {
                cert lab.local.crt
                chain lab.local.crt
                key lab.local.key
        chain lab.local.crt
        ciphers DEFAULT
        defaults-from clientssl
        inherit-certkeychain false
        key lab.local.key
        passphrase none
        peer-cert-mode require
    Thanks! Rafael
  • I did a tcpdump and I can see that when I try to connect through a browser (IE11), the browser establishes 4 connections and do 4 client hellos.
    But when I connect through "openssl s_client -connect 192.168.1.43:443" and do a "GET / HTTP/1.0" I get the same page but only one connection:
    I uploaded both captures to cloudshark:
    Connection from Linux box (only one SSL client hello) - https://www.cloudshark.org/captures/63c678837a25
    Connection from IE11 (4 SSL client hellos) - https://www.cloudshark.org/captures/f6924bd9ecaa
    Thanks! Rafael
