Zuke_254875's avatar
Zuke_254875
Mar 02, 2018
SSH connections prompting for password
I have a situation where a couple of guests are prompting a server for a password. These guests have the correct key in /.ssh/authorized_keys; other guests with identical authorized_keys do not prompt the server for a password.
Rebooting the guests did not fix the issue. I am able to authenticate with my cert/key no problem.
  • Check permissions and contexts on the files in .ssh. This won't work:
    # ls -lZ
    lrwxrwxrwx. root webusers system_u:object_r:unlabeled_t:s0 authorized_keys -> /var/ssh/root/authorized_keys
    lrwxrwxrwx. root webusers system_u:object_r:unlabeled_t:s0 identity -> /var/ssh/root/identity
    lrwxrwxrwx. root webusers system_u:object_r:unlabeled_t:s0 identity.pub -> /var/ssh/root/identity.pub
    lrwxrwxrwx. root webusers system_u:object_r:unlabeled_t:s0 known_hosts -> /var/ssh/root/known_hosts
    but this will:
    # ls -lZ
    lrwxrwxrwx. root root unconfined_u:object_r:ssh_home_t:s0 authorized_keys -> /var/ssh/root/authorized_keys
    lrwxrwxrwx. root root unconfined_u:object_r:ssh_home_t:s0 identity -> /var/ssh/root/identity
    lrwxrwxrwx. root root unconfined_u:object_r:ssh_home_t:s0 identity.pub -> /var/ssh/root/identity.pub
    lrwxrwxrwx. root root unconfined_u:object_r:ssh_home_t:s0 known_hosts -> /var/ssh/root/known_hosts
