Technical Forum
Servers not reachable from BIG-IP, following keith barker CBT nuggets lab
Shah101
Hi Everyone, i am following Keith barker CBT nuggets videos and lab. as shown in the lab i have deployed three servers but i am not able to ping any of them from BIG-IP.
>> Servers are reachable from my PC
>> no server are pingable from BIG-IP
>> can't ping any ip of BIG-IP other than mgmt ip from my PC.
C:\Users\ds>ping 10.2.0.11
Pinging 10.2.0.11 with 32 bytes of data:
Reply from 10.2.0.11: bytes=32 time=2ms TTL=64
Reply from 10.2.0.11: bytes=32 time<1ms TTL=64
Ping statistics for 10.2.0.11:
  Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
  Minimum = 0ms, Maximum = 2ms, Average = 0ms
C:\Users\ds>ping 10.2.0.145
Pinging 10.2.0.145 with 32 bytes of data:
Request timed out.
Ping statistics for 10.2.0.145:
  Packets: Sent = 1, Received = 0, Lost = 1 (100% loss),
1 REPLY 1
crodriguez
Legacy Employee
Legacy Employee
The first thing that comes to mind is that your BIG-IP VLANs and interfaces are not "singing from the same sheet of music" as the network adapters.
  1. Check the VLANs on your BIG-IP system to determine which interface(s) each uses - tmsh list net vlan interfaces
  2. Check the MAC addresses for each BIG-IP interface - tmsh list net interface mac-address
  3. Map the interface MAC addresses to their respective Network Adapter on the VM
  4. Finally, make sure each Network Adapter on the VM is assigned to the correct network.
