Technical Forum
Send /var/log/ltm on syslog destination without AUDIT logs
bortega_340015
Hello everyone,
I'm trying to filter just /var/log/ltm logs in F5 version 13.1.1.4, but with my configuration I can't filter the AUDIT logs, is still sending it to my syslog destination.
I configured this in syslog all-properties:
include " filter syslog_level { facility(local0) and level(debug..crit); };
filter no_audit {        not match ("AUDIT");    };
destination remote_server {
    udp(\"172.16.10.26\" port(4000));
log {
    source(local);
    filter(syslog_level);
    filter(no_audit);
    destination(remote_server);
But, when I tried to restart the service syslog-ng, shows the next message: WARNING: the match() filter without the use of the value() option is deprecated and hinders performance, please use a more specific filter like message() and/or program() instead.;
Any ideas how can I just receive /var/log/ltm on my syslog destination?
Thanks in advanced.
1 ACCEPTED SOLUTION
AMiles_377865
Cirrocumulus
Cirrocumulus
Hello Berenice,
You're on the right track; your syntax is just a little off. Match now requires the use of "value()"
So I think something like
filter no_audit { not match ( value=("AUDIT") );    };
Reference: Syslog Guide 3.0
Best of luck,
Austin
3 REPLIES 3
AMiles_377865
Cirrocumulus
Cirrocumulus
Hello Berenice,
Best of luck,
Austin
Hello Austin,
Thanks for your help. I modify the filter as you told me, but it shows a syntax error. However, your reference helps a lot. I find how to configure the filter like:
filter no_audit { not match (AUDIT value(MESSAGE) ); };
And it worked. Thanks.
Hello
did it change in 17.1*?
