Self IP and Virtual IP
Like to know about the relationship between self ip and the virtual ip in F5? Of course I did read the article (https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos-routing-administration-11-6-0/5.html) but our F5 version in on 12 and I am unable deduce how these two elements work/communicate. Can you kindly help me to explain me on this.
- Simon_Blakely
Employee
The self-IP defines the IP address range of the associated VLAN.
Virtual IPs (addresses) should be in the same IP address space as specified by the self-ip/vlan.
This means that the Virtual Addresses share the MAC address of the (floating) self-IP, and this is the MAC address sent out when the LTM sends Gratuitous ARPs for Virtual Addresses after going Active.You can create Virtual Addresses that are not in the self-IP address space of the VLAN. You need to provide explicit routing for the Virtual Address to the self-IP in this case.
Also, the LTM will not send Gratuitous ARPs for such Virtual IPs after going Active - this may cause traffic issues when failover occurs. - SurgeonRet. Employee
If you had a chance to work with routers or multilayer switches then self-ip address is analog of ip address of SVI interface.
Loopback IP is similar to VIP IP (it is very rough though). But on big-ip self-ip and VIP ip share the same MAC of the VLAN they belong to.
VIP is dataplane
self-ip is sort of control planeAll service traffic goes via virtual IPs only. Device control traffic goes via self-ips only.
I hope that make sense. If not, please provide more details what you are looking for.
