11-Feb-2020 11:58
Hello,
I have a VS that am setting up that is pointing to an IIS backend server that is configured to only respond to an address (IE test1.address.com). I need to find a way for my VS to point to this without changing the URL in the browser so the following happens:
User goes to "test.address.com" (which is the VIP of my VS).
This actually points to "test1.address.com", but the user only sees "test.address.com" in their browser.
Is this possible?
Thanks!
11-Feb-2020 13:00
This is what is known as a "reverse proxy"
AskF5 | Manual Chapter: Configuring the BIG-IP System as a Reverse Proxy Server
Use a Rewrite profile to translate any absolute references and Host headers in the HTTP request/response to match the external name.
If the pool member is accessed over HTTPS, you will probably need to create a server-ssl profile that specifies the Server Name, so the ClientHello includes the correct extension for Server Name Indication (SNI).
