08-Dec-2020
03:20
- last edited on
05-Jun-2023
23:04
by
JimmyPackets
Hello,
I would like to ask which trafic exactly is included in maximum allowed throughput license rate. I know it is ingress and egress as described here https://support.f5.com/csp/article/K15831 but I dont understand if it is all trafic on all interfaces or it is only on WAN interface and how I can measure this
I tried this command
bigtop -bytes -delta -vips none -delay 1bigtop -bytes -delta -vips none -delay 1
but it shows that it is save under license limit but we are getting notification that we are reaching limitation and BIG-IP dropping ingress packets but only ingress
so my questions are:
thank you
04-Jan-2021 07:53
Hello Roman.
Throughtput is limited by TMM instance.
https://support.f5.com/csp/article/K14356
The difference between ingress and egress is described here
Regards,
Dario.
