14-Nov-2022 03:02
Hello
Please provide me with full set of technical documents for for any BIGIP product
Solved! Go to Solution.
14-Nov-2022 07:51
If you look at https://techdocs.f5.com/en-us/hw-platforms/platform-guide-i2000i4000-series/title--platform-specific...
you will see EN 55032 certification:
ETSI EN 300 386 V1.6.1 (2012)
EN 55032:2012/AC:2013
EN 61000-3-2:2014
EN 61000-3-3:2013
As for the other requirements, create an F5 Support case and ask whether it is certified to those specifications.
14-Nov-2022 07:28
You need to lookj at the hardware documentation. Go to https://support.f5.com/csp/knowledge-center/hardware and look for the required hardware. Go to Platform Specifications, for instance https://techdocs.f5.com/en-us/hw-platforms/platform-guide-i2000i4000-series/title--platform-specific...
14-Nov-2022 07:39
Hello
I looked but no documentas I need are shown there
14-Nov-2022 07:43
OK, can i suggest that you provide more information about your requirements then. Which hardware platform do you require the certificate for? Maybe you should contact F5 directly if you have specific requirements - raise a support case and be specific about exactly what you want.
14-Nov-2022 07:45
These document are needed in order to import F5 product to ISRAEL. they are rquired by the custom.
I need it for the i2000/4000 and if you also for ant Rseries
Ronen
14-Nov-2022 07:51
EN 61000-3-2:2014
EN 61000-3-3:2013
22-Nov-2022 09:28
@Ronenb - I'm marking this as Solved. If you disagree you may unselect the solution, select other replies as solutions, or continue the conversation as necessary. Thank you.
Lief
