Gajji's avatar
Gajji
Feb 15, 2021
Solved
Please confirm if below scenario is feasible
Please confirm if below scenario is feasible( check if we can define LB vip in the backend pool under another VIP).
VIP 1 and VIP 2 both will have VIP 3 as a pool member.
  • If VIP 3 is hosted in a different BIG-IP it should work.
    However, if it's in the same box, it's unlikely to work:
    "BIG-IP does not respond to its own Address Resolution Protocol (ARP) requests for locally-hosted virtual server addresses, and thus is unable to establish a network connection to a locally-hosted virtual server. As a result, if you add a locally-hosted virtual server to a BIG-IP load balancing pool, no traffic will ever be sent to that pool member, as it is not possible for the system to load balance traffic to that pool member."
    K10379: A local virtual server IP address cannot be used as a pool member
    https://support.f5.com/csp/article/K10379
