Stanley_87566
Jan 06, 2010Nimbostratus
Packet reset when call Virtual Server
Hi All,
I found a performance problem when an application call a Virtual Server on my BIPIP 3400.
The problem is some packets will be reset during 3 ways handshake and before load-balancing. Even though some request luckily successfully load balance to the node (web server). The transaction need time is very long. So that transaction timeout caused. However, when that application call the Node (web server) IP address directly, all problem disappeared.
I'm using "BIG-IP 9.4.5 Build 1086.1 Hotfix HF2" with layer 2 network configuration (External and internal interfaces are same segment and both external and internal interface connecting to 100baseTX full). Therefore, the problem should not because of other network equipment when I tried to bypass the virtual server and the node real IP address.
Is any have idea or experience it?
Many thanks!
