27-Apr-2021 07:06
I actually planning to create an HA for both of my BIGIP servers.
Issue:
Note: I don't know how to setup my NTP server, I just used the IP of my test server as NTP
Regards,
Renato Alcala
28-Apr-2021 00:47
up
28-Apr-2021 01:30
you can force config sync from tmsh with command ( run cm config-sync force-full-load-push to-group <group name> )
this command will push configuration from device you are logged on to group
28-Apr-2021
02:00
- last edited on
24-Mar-2022
01:27
by
li-migration
hi ,
I already done executing the command but still nothing happens 😞 .. Thanks for the reply sir.
Regards,
Renato
