NGINX(ingress controller)-F5 integration
Hello Team
I am working on integrating F5 and NGINX(ingress controller) as per below article
I have created F5 Container Ingress Services as per the link and have couple of questions
- --bigip-username=$(root) --> this is GUI or CLI username and does it have to bracket, like mentioned
- --bigip-password=$(shivshiv) --> this is GUI or CLI username and does it have to bracket, like mentioned
- --bigip-url=https://192.168.178.44:8443 --> do we need port 8443 to be mentioned or can i just put https://192.168.178.44:
Also added
envFrom:
- configMapRef:
name: as3-template ->> do we need to call config map here, its not part of yaml file in the above link
- secretRef: --> i have created using imperative model, does this is OK as opaque or we need to refer kubernetes.io/service-account.name: bigip-ctlr created for CIS controller
--insecure=true ( i understand this will allow the session to be established without exchanging certificate, or is this the requirement)
Once CIS controller been created and AS3 been defined, I understand i will be to connect with F5 and initial config can be done as specified in AS3. Is my understanding correct?
Also i have installed following package, is this requirement?
f5-appsvcs-3.17.1-1.noarch
Most importantly: Does this integration supported between open source NGINX or do we NGINX+ as ingress controller ?
Looking forward to the response.
Thanks a lot in advance
Kind Regards
Kunal
