Technical Forum
Network map to excel
Anju
Altostratus
Altostratus
Hi Folks,
How can we get network map info - VIPs, Pool, nodes etc. in a spreadsheet? I need to make a spreadsheet for complete configuration of the device, any quicker way to do it?
7 REPLIES 7
Daniel_Wolf
Nacreous
Nacreous
Hi Anju,
I think  has you covered - Export Virtual Server Configuration in CSV - tmsh cli script
KR
Daniel
Hi Daniel,
Thank you for your response. I did run the script, but it dint work out for me. Please take a look at the below output i got.-
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ # tmsh list cli script virtual-details
01020036:3: The requested shell script (/Common/virtual-details) was not found.
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ # cli script virtual-details {
bash: cli: command not found
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ # proc script::run {} {
bash: proc: command not found
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ #  puts "Virtual Server,Destination,Pool-Name,Profiles,Rules"
bash: puts: command not found
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ #  foreach { obj } [tmsh::get_config ltm virtual all-properties] {
bash: foreach: command not found
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ #    set profiles [tmsh::get_field_value $obj "profiles"]
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ #    set remprof [regsub -all {\n} [regsub -all " context" [join $profiles "\n"] "context"] " "]
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ #    set profilelist [regsub -all "profiles " $remprof ""]
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ #    puts "[tmsh::get_name $obj],[tmsh::get_field_value $obj "destination"],[tmsh::get_field_value $obj "pool"],$profilelist,[tmsh::get_field_value $obj "rules"]"
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ #  }
bash: syntax error near unexpected token `}'
[XXX@UNIT-01:Peer Time Out of Sync:Changes Pending] ~ #  total-signing-status not-all-signed
bash: total-signing-status: command not found
Looking for an output from a particular partition in bash. Not sure, how can I achieve this. Let me know if you can help on this. Thanks.
Tried the one in the article - https://support.f5.com/csp/article/K44010967, its giving below output (used 'grep' instead of 'awk' since grep is only supported on these units) its giving the blank csv file. extracted from winscp, nothing was found.
Daniel_Wolf
Nacreous
Nacreous
Hi Anju,
I think you missed part of the instructions. First you run
tmsh create cli script virtual-details
in order to create the script. Then you paste from line 52 to the end of the code snippet.
Next you run
to verify the script was created successfully.
And then you run.
tmsh run cli script virtual-details > /var/tmp/virtual-details.csv
This will write the results to the CSV.
As for your question regarding K44010967... as far as my memory reaches back, 'grep' and 'awk' are always available. I cannot recall a BIG-IP version that would not have 'awk' in bash. Also you cannot replace them with the another. The 'grep' command searches for lines matching a regex pattern while 'awk' is for string, arithmetic, and time manipulation.
Hi Daniel,
Tried the script as suggested, its giving the error - command not found. The below was found when tried on common partition -
when tried in bash, found the below error-
virtual-details: script failed to complete:
script "virtual-details" does not contain a "script::run" procedure
script did not successfully complete, status:1
Need to know what am i doing wrong here?
Apologies, maybe I was not 100% clear. With this snippet you create the script.
Next switch to tmsh and run:
root@(awaf)(cfg-sync Standalone)(Active)(/Common)(tmos)# edit cli script virtual-details
Here is a screenshot:
0691T00000BVBkfQAH.pngNow a vi-style editor will open you must paste from line 52 to line 88 the end of the code snippet. Verify that copy&paste worked. In my test, the proc from line 52 was not pasted, I had to type it manually.
Also exit this editor in vi-style with :wq. You will additionally be prompted whether you want to save the script.
Now run this command to verify your changes were saved.
If everything looks good, run the script. Here is a screenshot from a successful run:
One more thing... this is how the script editor looks in my environment after I pasted the script. I tested on 15.1.2.
