Need original client IP on SMTP VIP
F5SJ_
Altocumulus
Altocumulus
We have one VIp on port 25 in which we want to allow origin client ip. We asked server team to change the default route that will point to floating self ip of the VIP, that didn't work.
I configured http profile on the VIP and enabled x-forwarder that didn't work too. Kindly provide some solution to fix the problem.
VIP config:
ltm virtual xxxx {
  description xxxx
  destination x.x.x.x%RD:smtp
  ip-protocol tcp
  mask xxxx
  partition xxxx
  persist {
    /Common/source_addr {
      default yes
  pool xxxx
  profiles {
    /Common/tcp { }
  source 0.0.0.0/0
  source-address-translation {
    type automap
  translate-address enabled
  translate-port enabled
2 REPLIES 2
F5SJ_
Altocumulus
Altocumulus
I searched some docs in devcentral and prepared one irule.
when CLIENT_ACCEPTED {
  set c-addr [IP::client_addr]
  log local0. "Client addr: $c-addr"
  STREAM::expression {@^EHLO.*@@ @^HELO.*@@}
  STREAM::enable
when STREAM_MATCHED {
  set mstring [STREAM::match]
  log local0. "STREAM_MATCHED: string: $mstring"
  set replacment [string range $mstring 0 1]
  append replacment "LO $c-addr\r\n"
  log local0. "STREAM_MATCHED: replacement string: $replacement"
  STREAM::replace $replacment
  event STREAM_MATCHED disable
when SERVER_CONNECTED {
  STREAM::disable
Will that work?
F5SJ_
Altocumulus
Altocumulus
Can someone pls update me on this..
