12-Oct-2023 00:43
Hello All, we are working to to extract the device SerialNumber from the certificate send it as "X-Common-Name" header to the servers.
Could you please help if you would have worked on the similar iRule in the past?
Regards,
Thiyagu
12-Oct-2023 01:01
HI @Thiyagu ,
Have a look here : https://community.f5.com/t5/codeshare/extracting-the-sni-server-name/ta-p/288029
I haven't tried this irule , but it looks good
12-Oct-2023 01:23
Hi Mohamed, Thank you so much for your help. We are authneticating via mutual TLS and SN# of cert needs to extracted and pass it along in the HTTP header as X-Common-Name.
Thanks,Thiyagu.
12-Oct-2023 01:41
ohh ,
so you need to extract this tls extension and insert it as a header to server side ?
you need to insert SNI as header " X-common-name "
Let me check for proper irule , I did before somthing like that , but it was another tls extension
12-Oct-2023 02:23 - edited 12-Oct-2023 02:24
Hi @Thiyagu ,
you can use something like this :
when CLIENTSSL_HANDSHAKE {
if { [SSL::extensions exists -type 0 ] } then {
set tls_sni_extension [SSL::extensions -type 0 ]
set tls_sni_extension ""
if { $tls_sni_extension ne "" } then {
log local0. " The X-common-name <---> $tls_sni_extension"
HTTP::header insert X-common-name "$tls_sni_extension"
I am not sure for type 0 as it depends , so could you please capture single request to see the sni extension ?
12-Oct-2023 22:58
16-Oct-2023 08:53
Sorry Guys for the confusion. We need to extract the below value in the client certificate (from Subject CN)
Common Name: xxxxxx
And it needs to insert in the HTTP header to the server as "X-Common-Name"
Could you please help with an iRule to meet this requirement?
16-Oct-2023 12:33
Hi @Thiyagu ,
you can use somthing like that : https://community.f5.com/t5/technical-forum/capturing-the-cn-from-a-x509-subject/td-p/226380
