29-Jan-2020 12:14
Our application developers are launching Mirth and I've setup a Standard VIP listening on 443, http profile, with client/server ssl profile and an iRule (uri based). The server cert portion is working just fine, but was informed yesterday that they needed the client cert to be passed along to the pool members. After doing some reading, I set both profiles to Proxy SSL. Once I set that, they immediately saw SSL handshake failures. From a SSLDUMP I am seeing the following:
# ssldump -r /var/tmp/proxycap.pcap
New TCP connection #1: 10.144.22.176(53294) <-> 10.144.20.176(443)
1 1 0.0008 (0.0008) C>S SSLv2 compatible client hello
Version 3.3
cipher suites
TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
TLS_RSA_WITH_AES_256_CBC_SHA256
TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384
TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384
TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
TLS_DHE_DSS_WITH_AES_256_CBC_SHA256
SSL2_CK_3DES
TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
TLS_RSA_WITH_AES_128_CBC_SHA256
TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256
TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256
TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
TLS_DHE_DSS_WITH_AES_128_CBC_SHA256
SSL2_CK_DES
SSL2_CK_RC4
TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
TLS_RSA_WITH_AES_256_GCM_SHA384
TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384
TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384
TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
TLS_DHE_DSS_WITH_AES_256_GCM_SHA384
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
TLS_RSA_WITH_AES_128_GCM_SHA256
TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256
TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256
TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
TLS_DHE_DSS_WITH_AES_128_GCM_SHA256
TLS_EMPTY_RENEGOTIATION_INFO_SCSV
Unknown value 0xa7
Unknown value 0xa6
TLS_DH_anon_WITH_AES_256_CBC_SHA256
Unknown value 0xc019
TLS_DH_anon_WITH_AES_128_CBC_SHA256
Unknown value 0xc018
TLS_RSA_WITH_DES_CBC_SHA
SSL2_CK_DES
TLS_DHE_RSA_WITH_DES_CBC_SHA
TLS_DHE_DSS_WITH_DES_CBC_SHA
TLS_DH_anon_WITH_DES_CBC_SHA
TLS_RSA_WITH_NULL_SHA256
Unknown value 0xc006
SSL2_CK_RC2_EXPORT40
Unknown value 0xc010
Unknown value 0xc001
Unknown value 0xc00b
Unknown value 0xc015
TLS_RSA_WITH_NULL_MD5
Unknown value 0x1e
Unknown value 0x22
1 2 0.0063 (0.0055) S>C Alert
level fatal
value handshake_failure
1 0.0064 (0.0000) S>C TCP RST
The F5 is a 1600 running 12.1.2 code. let me know if I am overlooking something or there is a better way to perform this for the app team. Thanks.
29-Jan-2020 14:08
As it appears that the pool member requires information from the client-side client auth certificate, you really need to use:
K72668381: Overview of the SSL Client Certificate Constrained Delegation feature
which requires upgrading to 13.1.x
K14065425: Configuring Client Certificate Constrained Delegation (C3D)
29-Jan-2020 14:31
K9476: The F5 hardware/software compatibility matrix
1600 - BigIP 12.1.2
Get a Virtual Edition License ...
05-Feb-2020 07:46
Alright, back again. We had a 4200 unit lying around which was recently reclaimed from another location. I've wiped it clean and upgraded the software to BIG-IP 15.1.0 Build 0.0.31 Final. I've duplicated the VIP setup from lat time and appending in the C3D pieces to the client/server ssl profiles. I seem to be stuck at the client cert handshake:
New TCP connection #3: 10.93.169.32(57353) <-> 10.144.20.10(443)
3 1 0.0515 (0.0515) C>S Handshake
ClientHello
Version 3.1
cipher suites
TLS_RSA_WITH_3DES_EDE_CBC_SHA
compression methods
NULL
extensions
server_name
status_request
supported_groups
ec_point_formats
SessionTicket
extended_master_secret
Unknown extension (0x18)
renegotiation_info
3 2 0.0526 (0.0010) S>C Handshake
ServerHello
Version 3.1
session_id[32]=
cf e2 d9 64 73 36 1d d9 56 ca c2 8c 7b 9e 65 82
b8 b5 15 06 e3 01 d1 9a 1a 6c 08 82 8b 6e f5 d0
cipherSuite TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
compressionMethod NULL
extensions
renegotiation_info
ec_point_formats
3 3 0.0526 (0.0000) S>C Handshake
Certificate
3 4 0.0526 (0.0000) S>C Handshake
ServerKeyExchange
3 5 0.0526 (0.0000) S>C Handshake
CertificateRequest
certificate_types rsa_sign
certificate_types dss_sign
certificate_types ecdsa_sign
3 6 0.0526 (0.0000) S>C Handshake
ServerHelloDone
3 7 0.1059 (0.0533) C>S Handshake
Certificate
ClientKeyExchange
CertificateVerify
3 8 0.1059 (0.0000) C>S ChangeCipherSpec
3 9 0.1059 (0.0000) C>S Handshake
3 10 0.1063 (0.0003) S>C Alert
level fatal
3 0.1063 (0.0000) S>C TCP FIN
3 0.1342 (0.0279) C>S TCP FIN
New TCP connection #4: 10.93.169.32(57354) <-> 10.144.20.10(443)
4 0.0203 (0.0203) C>S TCP FIN
4 0.0203 (0.0000) S>C TCP FIN
(cfg-sync Standalone)(Active)(/Common)(tmos)#
05-Feb-2020 18:26
You probably need to capture both the client and server-side handshakes at the same time.
You may be getting a server-side authentication failure when the forged certificate is passed to the pool member.
