joulate's avatar
joulate
Nov 28, 2018
NAT with ZebOS
Hello Guys. Anyone knows if I can use NAT in ZebOS ? As per the article below looks like it is possible:
https://support.f5.com/content/kb/en-us/products/big-ip_ltm/manuals/related/arm-basic-access-configuration-7-8-1/_jcr_content/pdfAttach/download/file.res/arm-basic-access-configuration-7-8-1.pdf
But when I access my ZebOS module I do not have the access to the NAT commands:
ltmtestip ? as-path BGP autonomous system path filter bfd Bidirectional Forwarding Detection (BFD) community-list Add a community list entry extcommunity-list Add a extended community list entry igmp Internet Group Management Protocol (IGMP) mroute Configure static multicast routes multicast Global IP multicast commands multicast-routing Enable multicast routing pim Protocol Independent Multicast (PIM) prefix-list Build a prefix list route Establish static routes static static routes
Looks like NAT uses linux netfilter:
"The IMI provides Network Address Translation (NAT) in net filter, the packet-filtering framework in the Linux 2.4 and 2.6 kernel"
Is there any other step I need to enable to have NAT feature?
Thanks.
