mfang-core_6053's avatar
mfang-core_6053
Feb 08, 2011
Monitoring Pool Statistics Cacti
Hi All,
I'm using BIG -IP LTM 6900 9.4.8 Build 396.1 Hotfix HF3 from recent upgrade 6400 to 6900. The issue I'm running into is the Pool Statistics is returned no data.
+ Running data query [14].
+ Found type = '3' [snmp query].
+ Found data query XML file at '/usr/share/cacti/resource/snmp_queries/f5_bigip_pool.xml'
+ XML file parsed ok.
+ Executing SNMP walk for list of indexes @ '.1.3.6.1.4.1.3375.2.2.5.2.3.1.1'
+ No SNMP data returned
