Foxmc's avatar
Foxmc
Apr 30, 2021
Modifying a pool member state through the SDK - Big IP
Hi everyone, as the title says I am trying to modify a pool member state through the SDK with a script.
However, I am having trouble to modify its state, I am running the following commands after loading the pool member:
member.update(description='new description', state='down')
print(member.raw)
print(member.description)
The description is update, however, the state shows 'up'. Any leads what I am doing wrong?
Thanks in advance, and I am sorry if this is a very basic question.
  • Foxmc's avatar
    Foxmc
    Just solved this problem, it was the syntax, I should have used "user-down".
