Technical Forum
Custom Alert Banner
management interface failover
MAbbas
Cirrus
Cirrus
hi -
my HA pair (11.6) failed over because the lost connection on management interface
010c007e:5: Not receiving status updates from peer device /Common/<devicename> (5.5.5.5) (Disconnected).
how can i disable f5 s to failover - if management interface has problems
1 ACCEPTED SOLUTION
i looked around in KB articles and got the answers to all 3 question - so all good
5 REPLIES 5
​Hi  , Normally failover configuration is present under Devices --> Failover Network where the IP addresses for failover are configured. But it is recommended to have the MGMT IP address and a TMM Network Address under failover configuration. You can refer below document.
https://support.f5.com/csp/article/K14135
Hope it helps!
Mayur
MAbbas
Cirrus
Cirrus
thanks for the response - i do have a failover network - which did not have any issue - i could not see and interface going down in logs - - management interface is not in network
so question is - is the management interface there by default - as i dont have it in failover
network failover check box is - checked
Hi, F5 uses only ip addresses configured under failover config for exchanging the heart beats & checking the health of the peer device.
thanks for the reply
the problem i am facing that - heartbeats are dropping and both devices are constantly becoming active - i dont see any issue on the hypervisor side (network interface).
question -
1 - how many heartbeats need to fail for the device to become active ?
2 - can i tweak those settings ?
3 - if i add a third network - would both of them have to fail for device to become active ?
thanks
