15-Nov-2018
06:23
- last edited on
01-Jun-2023
16:35
by
JimmyPackets
Hi all,
I'm having an issue with LTM policies to insert header on response. Here's the working configuration 1 policy with 3 rules
rules {
Pool1_rule {
actions {
0 {
forward
select
pool Pool1
1 {
http-header
response
insert
name Content-Security-Policy
value "frame-ancestors 'self';"
2 {
http-header
response
insert
name X-Content-Security-Policy
conditions {
0 {
http-host
values { pool1.mysite.com }
Pool2_rule {
actions {
0 {
forward
select
pool Pool2
conditions {
0 {
http-host
values { pool2.mysite.com }
ordinal 1
Pool3_rule3 {
actions {
0 {
forward
select
pool pool3
conditions {
0 {
http-host
values { pool3.mysite.com }
ordinal 2
status published
strategy /Common/first-match
This Policy works because the headers are added in the first rule. If you change the order of the rules, for example add the headers in the second rule the headers are not added on the response.
rules {
Pool2_rule {
actions {
0 {
forward
select
pool Pool2
conditions {
0 {
http-host
Pool1_rule {
actions {
0 {
forward
select
pool Pool1
1 {
http-header
response
insert
2 {
http-header
response
insert
conditions {
0 {
http-host
ordinal 1
Pool3_rule3 {
actions {
0 {
forward
select
pool pool3
conditions {
0 {
http-host
ordinal 2
status published
Is this a limitation in LTM Policies?
Thanks,
04-Dec-2018 10:12
In the working policy, the header-insert actions are taken when the HTTP Host is "pool1.mysite.com", but the host in the non-working policy is "pool2.mysite.com". Is this what you intended?
