JayanthLakshmipathy's avatar
Nov 07, 2023
Solved
Looking for a TMSH command to check traffic flow
Hi
I have few VS configured with source, destination and port as ANY. Its an early configuration, not sure whats the background. I can see traffic on all VS statistics.
Would like to check, is there any way to find our which traffic is transmitted via which VS?
I know source, destination and port of the traffic and can simulate the traffic to verify. Appreciate if anyone can share with me command or possibilities?
Thank you
Jay
  • JayanthLakshmipathy I'm not sure if a command exists that would show this because the typical connection table outputs source IP, source port, destination IP, destination port, and destination pool member. I think the only option to look at connections in a reactive way would be to perform a tcpdump with the following flags that would insert F5 information about where the traffic is going.
    tcpdump -nni 0.0:nnp host <client_IP> -w /shared/tmp/my_cap.pcap
  • Hello,
    You can filter by the client side IP if need to check which virtual server is selected.
    Command:
    #show sys connection cs-client-addr 192.168.8.1
    Output:
    Sys::Connections
      client IP                virtual server IP   source from F5 (self IP)      backend server
    192.168.8.1:54105 192.168.8.100:80     192.168.7.111:26379          192.168.7.100:80 tcp 4 (tmm: 1)
    There are also multiple options in show sys connection that you can check and verify with.
    command output explanation:
    https://my.f5.com/manage/s/article/K40033505
    command options:
    https://my.f5.com/manage/s/article/K53851362
    Thanks,
    Mohamed Salah
