25-Sep-2020 05:04
We have Requirement to Create Layer 7 Probe with blow String on F5 LTM
lriczupaswhd001.nam.pwcinternal.com:443/index.html
I am running IOS 13.1.3.4 .
Can SOme one Give Procedure and config Steps
26-Sep-2020
23:36
- last edited on
04-Jun-2023
21:16
by
JimmyPackets
Create custom HTTPS monitoring in F5 to monitor the page. Below command will help you to configure but basic troubleshooting needed per requirement.
# create ltm monitor https monitor_custom_https { defaults-from /Common/https send "GET /index.html HTTP/1.1\r\nHost: lriczupaswhd001.nam.pwcinternal.com\r\nConnection: Close\r\n\r\n" recv 200 }
Below will be output after monitor creatation.
adaptive disabled
defaults-from https
destination *:*
interval 5
ip-dscp 0
recv 200 # Change the string per requirements.
recv-disable none
time-until-up 0
timeout 16
. This is just an reference. https://support.f5.com/csp/article/K12531
