Technical Forum
keys repository in f5
lami
Hello,
Could you please answer me, do keys stored on F5 in ciphertext or plaintext format?
Also do all F5 integrate HSM module if not is the F5 is FIPS 140-2 compliant ?
Thanks so much
1 REPLY 1
Hello Lami.
The location is this
Certificates --> /config/filestore/files_d/Common_d/certificate_d/*
Keys --> /config/filestore/files_d/Common_d/certificate_key_d/*
And keys could be store in plain text or cipher text (using a passphrase).
Besides this, you can use HSM (F5 supports several vendors).
REF - https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/big-ip-system-and-net-hsm-imple...
More info about FIPS support
REF - https://www.f5.com/company/certifications
Regards,
Darío.
Regards,
Dario.
