02-Dec-2020 15:05
This has got to be simple but I can't figure it out!! 😞
Can anyone help me to write an iRule that will reference a data group list of IP addresses I want to whitelist on ASM? I don't want to deny IP's that aren't on the list, just to never block those on the list.
Thanks!
Tony
Solved! Go to Solution.
03-Dec-2020 15:57
You can log the unblocked requests from within the local traffic policy. (I had log statements in both my rules, but removed them for the answer above.) There is a log action that can be added on the disable ASM rule. For example:
ltm policy disable_asm_for_select_IPs {
controls { asm }
last-modified 2020-12-03:15:50:12
requires { http tcp }
rules {
actions {
0 {
asm
disable
1 {
log
write
facility local0
message "tcl:ASM disabled for allowed IP [IP::client_addr]"
priority info
conditions {
0 {
tcp
address
matches
datagroup no_ASM_IPs
enable_asm_for_all_traffic {
actions {
0 {
asm
enable
policy /Common/lab_8_manual
ordinal 1
status published
strategy first-match
03-Dec-2020 06:11
You can add whitelist ip in WAF/ASM under ip/subnet exception list. It will give more flexibility then iRule... Hope it will work.
03-Dec-2020 06:17
I have about 450 IP addresses to allow. I already have the data group list on the box, just need an iRule to reference it. Thanks.
03-Dec-2020 06:53
you can try something like this... Not tested yet. Please test in non prod device.
when CLIENT_ACCEPTED {
if {[matchclass [IP::client_addr] equals bypass_asm_class]}{
set disable_asm 1
#log local0. "[IP::client_addr]:[TCP::client_port]: Client matched bypass_asm_class datagroup."
set disable_asm 0
#log local0. "[IP::client_addr]:[TCP::client_port]: Client did not match bypass_asm_class datagroup."
when HTTP_CLASS_SELECTED {
if {[HTTP::class asm]==1}{
if {$disable_asm==1}{
log local0. "[IP::client_addr]:[TCP::client_port]: Disabling ASM for this request."
ASM::disable
log local0. "[IP::client_addr]:[TCP::client_port]: Not disabling ASM for this request."
ASM::enable
Set the log according to requirements and later disable it
03-Dec-2020 10:16
I'll test this out, thanks!
03-Dec-2020 11:21
The HTTP_CLASS_SELECTED event has been deprecated. Instead, you can use a local traffic policy to selectively enable and disable ASM, as Samir showed, using an IP address data group to make the comparisons. For example:
controls { asm }
last-modified 2020-12-03:10:38:38
rules {
actions {
0 {
asm
disable
conditions {
0 {
tcp
address
matches
actions {
0 {
asm
enable
ordinal 1
status published
It's important that the catch-all rule, enable_asm_for_all_traffic, be the second rule in the policy, and disable_asm_for_select_IPs be first. You would assign the local traffic policy to the appropriate virtual server, replacing the default one applied when you enable an application security policy on the virtual server.
Here is what my internal datagroup looks like. (You can use an external data group just as easily.):
ltm data-group internal no_ASM_IPs {
records {
10.10.10.30/32 { }
type ip
I tested this on BIG-IP ASM v15.1.0.
03-Dec-2020 13:12
Nice, I'll run this on my v16.0.1 lab. Thanks!
03-Dec-2020 14:37
Works great on v16, unfortunately I can't log the unblocked requests. Guess that's the lesser of the two evils. Off to dev. Thanks again!
03-Dec-2020 15:57
controls { asm }
rules {
actions {
0 {
asm
disable
1 {
log
write
facility local0
priority info
conditions {
0 {
tcp
address
matches
actions {
0 {
asm
enable
ordinal 1
status published
04-Dec-2020 09:14
Too awesome, thanks again for your help!
