Mohammad_1363's avatar
Mohammad_1363
Aug 26, 2021
iRule that can forward traffic based on endpoint and http-method
Hello iRule Guru
currently i have an iRule that is doing two things, 1: if the http uri has /path1/example/ or /path2/example/ the traffic should go to pool-example
2: then if host equals api.example.com replace the header with host api.newexample.com.
the above conditions are working fine but we discovered that application needs one more condition, the additional condition would be if the uri has version2/sport1 and http method is POST, forward traffic to sport pool, can you please help me to write that condition.
 if { [string tolower [HTTP::uri]] starts_with "/path1/example/" or [string tolower [HTTP::uri]] starts_with "/path2/example/"} {
      pool pool-example
 } elseif { [string tolower [HTTP::host]] equals "api.example.com" } {
HTTP::header replace "Host" "api.newexample.com"
pool api-newexample-com
  • You can try below code
    return
    switch -glob [string tolower [HTTP::uri]] {
     "/path1/example*" -
     "/path2/example*"
     pool pool-example
     "/version2/sport1*"
      if { [HTTP::method] eq "POST"} {
      pool sport_pool
       reject
     } default  {
      return
  • xuwen's avatar
    xuwen
          pool pool-example
     } elseif { ([HTTP::method] eq "POST") and ([HTTP::uri] contains "version2/sport1") } {
    pool sport_pool
