Mark_Givens_877's avatar
Mark_Givens_877
Oct 14, 2005
iRule help with ports and pools
I need to create an iRule that will redirect incoming connections for certain ports to specific pools. I'm not sure how to do it. I found an example for something similar for v.4. I need to do the same thing but for v.9. I also need to specify a pool for more then one port. Using the 4.x example below, I would need Pool1 to be used if ports 4080 through 4085 were accessed. Is there a way to specify a range of ports instead of ==?
rule AppMgt {
if (ip_protocol == 6 and server_port == 4080) {
use ( Pool1 )
else if (ip_protocol == 6 and server_port == 5080) {
use ( Pool2 )
else if (ip_protocol == 6 and server_port == 9080) {
use ( Pool3 )
else {
discard
Thanks for the help!!
