iHealth Upgrade Advisor not visible anymore
Krishnaanupala
Has F5 decommisioned the iHealth Upgrade Advisor ? as its not visible anymore,
1 ACCEPTED SOLUTION
Krishnaanupala
Got an update, That feature has been removed January 14th 2020, iHealth release notes from the following,
 https://ihealth.f5.com/qkview-analyzer/releaseNotes/2020-01-14
 January 14, 2020
 * Removed Upgrade Advisor
1 REPLY 1
Krishnaanupala
 January 14, 2020
