SylvainG_363444
Jun 05, 2018Nimbostratus
IDP Automation idpObjNameTag field
Hello, I'm using IDP Automation to register numerous IDP.
In the input XML, each IDP is identified by: ' target="_self">http://idp-unique-url-example">;
So, now I have to set the "idpObjNameTag" in F5 automation which will give the new IDP Connector name. How should I syntax the field? All my attempts seems to fail with message: "Tag value to create object name is empty".
I tried for eg.:
md:EntityDescriptor entityID
md:EntityDescriptor
entityID
I don't find any hint in the docs. Can anyone help? (v13.0.0)
