30-Mar-2023 02:36
Hello.
I was doing a test on the management firewall.
I don't want to respond when a client makes an ICMP request to MGMT.
I think I can do it by adjusting the settings in "Security Firewall Management-IP-Rules", but it doesn't work.
Any suggestions?
Solved! Go to Solution.
30-Mar-2023 22:31
It seems this is bug https://cdn.f5.com/product/bugtracker/ID760355.html
try this:
https://my.f5.com/manage/s/article/K61100530
30-Mar-2023 07:27 - edited 30-Mar-2023 07:32
You can use Platform->Security , if you want to deny ICMP to the management IP:
you can also have a look at packet filters if you want to filter on different interfaces/vlans:
30-Mar-2023 17:59
Dear mihaic
First all, Thank you for your Solution.
Unfortunalluy,, I did its config.
but not working 😢
30-Mar-2023 22:31
try this:
30-Mar-2023 23:13
Dear mihaic
Thank you so much!
I have a personal question.
The only thing that can answer this is...
A reference? Or is it a search skill?
31-Mar-2023 01:17 - edited 31-Mar-2023 01:19
search in this case
