Mick's avatar
Mick
Icon for Cirrus rankCirrus
Aug 06, 2019
HTTPS Virtual Server doesn't automatically direct existing connections to available pool member
Hi
We have the following scenario, HTTPS VS presenting a web application configured with 2 pool members, when we are logged into the application and when we test a failover by shutting a web server down, the F5 doesn't direct the session to the other available pool member. We need to force a refresh on the browser for the connection to re-establish to the available pool member. Both VS and pool members are configured with HTTPS
We have:
VS - HTTPS
  • SSL Client profile with Verisign certificate
  • SSL Server inscure compatible
  • Using APM profile
  • persistence profile dest_addr
  • Pool with 2 members using round robin load balancing.
We have a pretty simple VS setup. I would have thought the F5 will automatically redirect the session to the next pool member, but i need to hit refresh on the browser.
Any tips?
  • JG's avatar
    JG
    Have you applied a "OneConnect" profile to the virtual server?
  • Thanks JG, i tried that but no luck.
    I noticed in the ltm logs complaining about SSL Handshake to one of the web servers:
    SSL Handshake failed for TCP web server:443 -> F5 SNAT:33968, not sure if thats causing an issue. The web servers are configured with SSL but are using self signed certs not imported to the F5
  • thanks yes i saw this, would this be contributing to the issue i'm having though?
  • JG's avatar
    JG
    "When a pool member fails to respond to a health monitor, the system marks that pool member down. Persistence entries associated with the pool member are removed when a new connection matches the entry or when the timeout period is reached. If a new connection matches a persistence record that has not timed out, the BIG-IP system removes the old persistence record and creates a new entry." (K15095: Overview of the Action On Service Down feature).
    So a current or a persistent connection will still be forwarded to the failed server until the connection times out or is killed.
    With a OneConnect profile, the load balance decision is made based on each HTTP request, not just at the beginning of a TCP connection, as I understand it.
    It is probably better to get other issues (SSL) out of the way before testing this issue.
  • thanks JG, i've done some more testing and i think the issue is on the application side, i've tested the same VIP settings on another web application and it works ok
