HTTP monitor with specific curl command
Hello All,
Is it possible to integrate specific curl command as send string in HTTP health monitor?
I am able to run curl command from CLI and get good response, but similar command doesn't interprited in health monitor by F5.
command is as below.
curl -X GET http://10.10.10.3:8008/master -i -H 'Accept: application/json' -H 'Content-Type: application/json'
RESULT IS
HTTP/1.0 503 Service Unavailable
- Lidev
Nacreous
Hello Kalpesh,
Yes you can, you need to create a external monitor.
Take a look on this link https://support.f5.com/csp/article/K31435017
Regards
- Kalpesh
Altostratus
Thanks Lidev,
I tried this, but we need node specifc monitor. and in external monitor there is no possibility to check for response.
We need node to be UP if response code is 200 OK
- Lidev
Nacreous
If the goal is monitoring a node, you can't do a content check Monitor. The content check monitor is only available on pool/pool members
- Lidev
Nacreous
Hi
Ok cool, mark your answer as "the best" in order to pass your post as resolved 😉
