http-compression in low performance
Hi All
We have a LTM web accelerator running v11.1.
Behind LTM it is a ASP.net application which can be accessed via internet. The total of in and out internet traffic is about 100Mb. Most of the data is in text type. However, after enable http-compression, the http-compression in dashboard shows only 20Kb traffic in average!
The LTM has http-compression license up to 4Gb.
The compression in IIS has been turned off.
We have tried the selective compression options either URL or content type, but the results are the same. http-compression traffic is about 20Kb in average.
The setting in http-compression profile is follow LTM default.
In HttpFox, we can see most of the responses with type of http/html (some may up to 200KB or more) are non-compressed. Even do not have Content-Encoding header in respose.
Does it normal? Could anyone guide me to fix this issue?
Thanks!
Larry
