JG's avatar
JG
Mar 15, 2014
How to read "chassis_power_supply_status_stat"?
How do I interprete the following stats from the following two different devices?
Device 1:
 eud_info
12.2.0.1.0
name index status input_status output_status fan_status
pwr1     1      1            1             1          2
pwr2     2      1            1             1          2
Device 2:
 eud_info
12.12.0.4.0
name index status input_status output_status fan_status current_status
pwr1     1      1            2             1          1              0
pwr2     2      1            2             1          1              0
I suspect one device might have a problem.
  • gbbaus_104974's avatar
    gbbaus_104974
    Historic F5 Account
    I do note that you have used two different versions of the EUD tool , ie v12.2.0.1.0 and v12.12.0.4.0
    There are differences between the versions
    http://support.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/related/relnotes_eud.html
    Maybe run the tests again with the same version on both
  • JG's avatar
    JG
    That is an awful lot of stuff to read.
    I doubt that existing values of "fan_status" would change across releases, though. But it is possible that the devices might have different numbers of fans...
    gbbaus_104974
    Historic F5 Account
    Hi
    To me the matrix is showing PWR on the different components. There is an extra column in the later EUD output.(current_status)
    As for the fans: chassis_power_supply_status_stat | fan_status = 2
    Maybe check with support if this is a 'STATUS code' vs a ' of FANS'
